08-21-2024 11:33 PM
I’m going on a 2-day, 1-night trip to the U.S. this weekend. Then, four days later, I'm going back to the U.S. again. Should I add the roaming package just once, or will I need to do it twice?
08-21-2024 11:37 PM
@Fly1234 wrote:I’m going on a 2-day, 1-night trip to the U.S. this weekend. Then, four days later, I'm going back to the U.S. again. Should I add the roaming package just once, or will I need to do it twice?
Roaming add-ons last for 15 days. Assuming that enough data usage is included (if you're taking one with data), one add-on can be used for both trips.
