Question Regarding Switching Plans
nikkieknits
Hello,
Currently I am on the old type of plan where you get discounts for referrals from friends and family but I want to change to a plan that is currently offered.  If I change my plan, will it force me into the new points plan setup?  Any help would be appreciated because I don't want to lose my referral bonus.
Thanks
Yummy
Your rewards will stay as is as they are tied up with your account and not plan.
HALIMACS
@nikkieknits
You actually don't lose your referral bonus's on the new point system.   The $1 per cycle is simply converted to 1 point to cycle (1 point = $1)
However, the biggest loss when switching to Public Points is the loyalty aspect of rewards.
On Public Points, the max you can get is $10 (10 points) per year.
On the Legacy Rewards, after 5 years, you get $60 per year.
So for that reason alone, Legacy Rewards is superior to Public Points.
Some might argue the 5% bonus on Public Points gives more than the auto-pay discount reward.   Sure, if one is on the $65 plan they will get $3.25 worth of points each cycle.   However even over 12 cycles that only gives one $15 more rewards per year than the auto-pay discount.
So if you plan on sticking around for more than a few years, the Legacy Rewards remain superior.
Chalupa_Batman
Hello @nikkieknits
I am on the Legacy Rewards plan myself. I, on 3 occasions now have switched over to different plans. At no point have I lost any rewards. There is a page for rewards where you can switch over to the new Public Points system. Only YOU can switch over to the new system. Never switch over!
Phil_Adelphus
@nikkieknits   No you don't lose your old Rewards unless you deliberately make a change to Public Points.  Just changing plan doesn't do that
