Question About Current Subscription vs. Available $18 Plan
SagarMacherla
My current subscription shows a charge of $18, which includes 100 CW talk minutes and a 30-day plan with 250 MB of data.
However, under the “Subscription & Add-on Plans” section, I see a plan offering 1 GB of data with unlimited talk and text for the same price of $18, along with $0.36 in public points.
I would like to confirm whether these are two different plans. If so, do I need to subscribe to the $18 plan listed under “Subscription & Add-on Plans” in order to receive the improved services at the same price?
hi @SagarMacherla
nothing to lose to get this new $18 plan
new vs old:
1GB vs 250MB
4G speed (100Mbps) vs 3G speed (3Mbps)
unlimited calling vs 100 mins outgoing
Socrates8567
Hello @SagarMacherla
It's pretty much the same plan. Just 1GB instead of 250mb. Nice little upgrade. But if you choose to move on this offer, just don't change it right away! There will be two options. Change now or at Renewal. Choose renewal so you don't lose any money. Good luck and enjoy.
slusagm
the $18 - 1GB plan is almost a "free upgrade" to your current plan.   It has everything you have with the current old plan, but added the unlimited calls (instead of 100 minutes) and 4G data (100Mbps vs the current 3Mbps)
PM has the $3 increase earlier and this is a "compensation" offer.  Get it before it is gone.  Use Change on Renewal option
