Putting a hold on my service
Kan_t
Hi Team. I’m flying out of country and I want to hold my service for 6 months is that doable ?
HI @Kan_t
PM only allows the 90 days suspension or account will be closed
you can suspend it first, then come back around 80+ days and resume for 30 days and suspend again.  But keep track on the days as you don't want to miss the 90 days
@Kan_t
usually the account can only be suspended for 90 days, so a bit of work to keep it alive
This is what you need to do to keep alive the account:
PM only allows the account to be suspended for 90 days or your account will be permanently closed, and you will loss the number.
So, your option is temporarily suspending the account and reactivate for 30 days before the 90 days deadline.
Here is what you can do (assuming your Available fund = $0)
  1.  First, change plan to $15 plan (to reduce the cost to keep your number)
    (While this plan change saves you money, but please be aware that you might not be able to get back your current plan if that plan is no longer available when you are back.  If you are worried, or your current plan is already not available, skip this plan change step but you can still follow this pause subscription steps with higher cost)
  2.  Then disable "Subscribed" from Payment page (Payment page, Managed Subscription, toggle off the "Subscribed" there
  3.  On the next renewal date, since pre-authorized payment is disabled, it won't be renewed.
          Make note of that day 1 of the suspension date
  4. !!!!VERY IMPORTANT!!!   Come back at around 85th days after the first date of the suspension to make a manual payment to renew the account for 30 days.  You can simply click "Pay Now and Resume Services" button and follow the step to make a manual payment.
    If you have changed to $15 plan in Step 1, it will just cost you $15 for that 30-days cycle.
    After you make the payment, make sure you see clearly that the account status is changed to ACTIVE.  If not, you will either have to open ticket with PM support or come and seek help here in the Community.
    (Don't wait till the 89th or 90th days as My Account could be down for maintenance or payment could be an issue, you want to give yourself enough time to sort it out)
  5.  Make note of that date, again, the account will be active for 30 days only and will be suspended again after the 30 days.  Make note of the date it got suspended again.
  6.  As the Autopay toggle "Subscribed" is already toggled off, it won't renew after that-30 days cycle.
    I hope you will be back by then. You just need to change the plan back to the one you want and then reactivate and remember to enable Autopay again (toggle on "Subscribed")
    If you still not back to Canada by the end of that 90 days, then come back NO LATER than 85th date and repeat from step 4 again.
