Purchased Canada Wide minutes Add-on but no minutes as balance
deepakkumar
I purchased Canada wide 500 minutes which is showing as current Add-on but I am not able to use those minutes.
It is showing as Add-ons under My Current Add-ons.
Please activate the add-on on my account for using the add-on purchased minutes.
Thanks
7 REPLIES 7
@BlueB wrote:
@deepakkumar
We're always happy to help... does this mean it's all solved now?  If so, we'd love to hear what the problem was and what fixed it.  🙂
@deepakkumar - I would be curious, as well.
If it was just a restart of your phone, than creds. should go to @LEGO , as they mentioned that first.
BlueB
@deepakkumar
deepakkumar
Thanks for the guidance/info.
BlueB
@deepakkumar
Just wondering... where in Canada are you trying to call?  I'm guessing you've run out of minutes for the month?
Thanks
@deepakkumar
Did you reboot your phone after you purchased the addon?
IF not, reboot, and see if you can make a call.
Yeah as @LEGO JUST posted - 😆
fyi, you are posting on the Community where we are all members/customers just like you.
We do not have access to your account.
Only CSA's have access to your account; for future reference this is how they are contacted: https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
LEGO
@deepakkumar Try to reboot your phone and see if this would fix your problem.
JK8
Thanks
Are you on a limited plan minutes? Your plan minutes will be used up first before it uses your add on minutes. If calling out try putting a 1 in front of the number.
