Puk code
Rob19
I submitted a ticket how does it take for a response?
7 REPLIES 7
@Rob19   cool..  just monitor the Community inbox.  Just in case no one reply in 24 hours, message them again.
But as I said, i asked something earlier today and the response was quick, so, let's hope same for you
add: this is a manual process, not automated, so, it takes time  🙂
Rob19
I have submitted everything that was needed I thought it would only take minutes
Rob19
I’ve submitted everything
HarryPotter
You will be contacted by an agent through private messages on yoir Community Account. I suggest you to turn on notifications for private messages. That way, when an agent contacts you, you don't miss it and reply back within 24 hrs. Hope it helps!
@Rob19   in terms of how fast support comes back, looks like they are coming back fast.  I submitted a question and I got a reply within 30 mins.
so, just keep checking your Community inbox https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
@Rob19
understand you are trying to get the PUK ticket going
https://productioncommunity.publicmobile.ca/t5/The-Lounge/Puk-code/td-p/926262
https://productioncommunity.publicmobile.ca/t5/Get-Support/SIM-card-puk/td-p/923005
But did you submit your PUK ticket with the link https://urlshortner.tiia.ai/Oyn1L6?
if so, you just need to monitor your Community inbox (envelope icon on the top right  or https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage) after the ticket is opened.  CS Agent will reply you there
Hollister
@Rob19
Within an hour when it is not too busy…up to 48 hours when busy.
