SIM card puk
Rob19
I need my puk
@Rob19
you still have not got the PUK yet?
for this error , open ticket with PM support and they can provide you the PUK
open a ticket with PM Support using this direct link:  https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
Rob19
@Rob19 wrote:
I need the steps to unlock my SIM card
Only a Public Mobile customer support agent can provde you with the SIM card's PUK.  To get that, open a ticket using the chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If your phone is asking for a SIM Network Unlock PUK, that means that your phone is locked to another carrier.  That carrier would have to get the phone unlockeed for you.  In some cases, the manufactuer could also help.
Which message is it displaying on your phone's screen?
Rob19
@Rob19
You need to provide us more info. Like are you using a new phone on PM network? or You have been using SIM PIN for safety and entered it wrong multiple times and seeing a PUK unlick code prompt now?
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK."
call  Samsung 1-800-726-7864, The only info you will need to provide for a master unlock was the IMEI and where the phone was purchased
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
If the message is "SIM network unlock PIN" or "SIM ME lock code NP"  or  on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier unlock code. (PM would not be able to help with this)
