Puk code
Zuber
I locked my SIM card and it needs puk code, how do I get puk code
JL9
It usually means it's locked to a carrier. Good news is once you reach out to them it's pretty easy to get the code
@Zuber   is that the SIM card PUK you are looking for or device carrier unlock code?
SIM card PUK will be asked if you have previously setup a SIM PIN and you have entered the wrong one too many times
if it is the SIM card puk you are looking for ,  you can open ticket with this direct link :
https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
RossN
@Zuber @What is your exact message?did you put your sim in a different phone it could be that phone is carrier locked
