02-02-2020 12:07 PM - edited 01-05-2022 09:18 AM
I have a public mobile Sim card that is locked I need the PUK code to unlock it
Joining Public
03-25-2020 10:00 PM
@Farhana wrote:Hi this is farhana my sim is locked need a puk code to unlock my date of birth is xxxxxxxxxxxxx my account number is xxxxxxxxxxxxx
phone number xxxxxxxxxxxxx
@Farhana The reason for not showing that information here has to with the fact that you just provided enough information for someone to potentially take over your Public Mobile account or to port your number out to another carrier.
03-25-2020 07:57 PM
@Farhana please delete you personal information from the post. Use the 3 dots on the top right of your post.use @Staliger link above to contact the mods for the puk code. Thanks.
@computergeek541 please edit @Farhana post. Thanks.
03-25-2020
07:52 PM
03-25-2020
09:58 PM
computergeek541
edited by computergeek541
02-02-2020 01:14 PM
Here is a detailed explanation by one of the Oracle's Luddite. "SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this. "SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above. “PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card. The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card. If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it. Once the PUK is recovered and validated, you will be asked to choose a new PIN. Only Public Mobile's moderators can give you this type of code, which the device manufacturer cannot. Public Mobile's moderators can be contacted at the following address: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
02-02-2020 12:12 PM
@iamgodslad2 wrote:I have a public mobile Sim card that is locked I need the PUK code to unlock it
@iamgodslad2 If you need a code due to locked phone, contact your previous provider or phone customer service. If you are required PUK code for sim card, contact moderators who can help, click the "?" in lower right side of the page, type "contact moderator", and follow directions, OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
02-02-2020 12:09 PM
More details would be helpful.
What are the circumstances?
Are you a new customer?
Is your phone locked? What is the exact message your phone is showing?
That makes a difference....
02-02-2020 12:09 PM
Only mods can help with that. Use the green question mark and follow the prompts till you get to the ticket form to submit a help request to moderators.
02-02-2020 12:08 PM
@iamgodslad2 Contact a moderator and explain your situation . Click on the green questionmark in the white circle at the bottom right of your screen . This connects to the autobot Simon. Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket
