Puk Code
Ryanmc
I just got my son a new phone and the SIM card was working the last week.  Now it says sim locked and I need a puk code?
Ryanmc
Thanks I’ve sent a request to get the code.
tabi159w
You will have to contact a Moderator for help. You can reach one here.
Luddite
@Ryanmc
  • Reboot with the SIM installed. What is the exact message?
  • Call 611. What message do you hear about active/suspended?
  • Try a different active SIM in the phone.
gpixel
@Ryanmc if your son set up a sim pin and entered it wrong 3 times this triggers a PUK code and you will need to contact customer support for the code
make sure to check your inbox(top right corner envelope icon) periodically, for a message
Triguy
Here is a detailed explanation by one of the Oracle's Luddite. "SIM network PIN blocked. Enter SIM network PUK."  is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.   "SIM network unlock PIN"  is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.   “PIN unlock key (PUK)”  is a SIM-specific code used to prevent unauthorised use of a SIM card.  The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.  If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it. Once the PUK is recovered and validated, you will be asked to choose a new PIN. Only Public Mobile's moderators can give you this type of code, which the device manufacturer cannot. Public Mobile's moderators can be contacted at the following address:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
shep22
@Ryanmc
@Ryanmc contact the moderator  click the question mark bottom right corner to contact the moderators ask Simon the robot to speak to a human to generate a ticket mention puk code check envelope top right for a response they usually reply between 2-48 hours
