01-29-2021 07:35 PM - edited 01-05-2022 05:04 PM
How do I change my name in public statistics? I noticed some people are nicknamed but mine shows name.
01-30-2021 11:06 AM - edited 01-30-2021 11:07 AM
@Bear2 wrote:How do I change my name in public statistics? I noticed some people are nicknamed but mine shows name.
Can certainly see why you'd think your name is showing up somewhere in the public forum as opposed to private, since it is clearly under the heading of Public Statistics under one's own profile.
Another one of those crazy items PM needs to update - add it to the list.
01-30-2021 03:26 AM
Thank you @Korth I didnt even think to do that.
01-30-2021 03:21 AM
You can click on your own user profile while logged out to see what other users can see when they click on it.
01-29-2021 07:47 PM
@Bear2 wrote:It wasn't bear2 I want to change. I was just looking at my profile settings and it shows name and things I commented on etc. Can others see that or only me? It shows public statistics?
Ah ha - I see okay, well I do not see any other name other than Bear2 when I look you up.
No one should see your Profile settings you have set. But if find out otherwise, geez, let me know! 🙂
01-29-2021 07:43 PM
Ok good I thought everyone could see it. Thanks. That i just change in settings?
01-29-2021 07:41 PM - edited 01-29-2021 07:41 PM
Yes. Only YOU should see that name. But you can change it to anything anyways, so why not change it and be more comfortable about it.
01-29-2021 07:38 PM - edited 01-29-2021 07:40 PM
Nobody can see your name. If someone were to figure out logging in to your community account then they would. So make it fake anyway.
My settings/Personal/Personal Information
01-29-2021 07:38 PM
01-29-2021 07:37 PM
@Bear2 , where else are you seeing a different name for others?
01-29-2021 07:36 PM
Hi Bear2,
If you want to change "Bear2" you will need to request that change be made with the moderators.
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
