03-25-2019 10:39 PM - edited 01-05-2022 06:59 AM
I'm wondering if public mobile to public mobile calls are counting agains the minutes in the limited plans?
Thanks.
03-27-2019 01:35 PM
@zombie999 wrote:Thanks for the info. I went with the unlimited plan.
@zombie999 even better!
03-27-2019 12:01 PM
03-27-2019 12:51 AM
@zombie999 wrote:OK, thanks. And when you are out of minutes, are calls sent to voicemail?
Lots of good tips and responses in this thread! To add to what everyone has stated, if you're using one of the 50 or 100 minute plans:
03-26-2019 02:04 PM
And the addon he mentions doesn't expire. Minutes carry over to the next cycle until they are used up.
GC
03-26-2019 01:50 PM
These calls should be sent directly to voicemail, but your phone won't ring. To retreive the voice messages, you would have to check from another phone.
@zombie999 you can also purchase the $8 200 long distance minutes add-on or the the $15 400 long distance minutes add-on with the limited minute plans and use them once your base minutes are used up.
03-25-2019 10:53 PM - edited 03-25-2019 10:53 PM
03-25-2019 10:47 PM
03-25-2019 10:42 PM
@zombie999 wrote:I'm wondering if public mobile to public mobile calls are counting agains the minutes in the limited plans?
Thanks.
For plans with a limited amount of minutes, these calls count the same as any other.
