Public mobile SIM not working in GPS tracker. when the SIM in the tracker it shows offline.Pls give
Nass3
SIM card not working when installing in GPS car tracking. When inside the tracker shows offline. Other SIM card that I have would work.
what is the problem. Any suggestions.
thanks
@Nass3
not much spec on this thing.  You need to ask them what network bands it works on.   But look likeit is not something work on this network
Nass3
The tracker is TK 913 V Winnes
thanks
slusagm
@Nass3
this is not a PM problem but your GPS tracker.  Your GPS tracker does not have the network bands PM uses.  Or it needs some APN update.  It should have the same problem if you put in Telus or Bell sim card.
what brand is that?
