Public Mobile compatible
Randman
Is the Umidigi note 100 5G compatible with Public Mobile in Canada
@Randman
Yes the Umidigi Note 100 5G is compatible with PM.
https://www.kimovil.com/en/frequency-checker/CA/umidigi-note-100-5g
will13am
@Randman , I have a Umidigi A13 pro and both VoLTE and 5G work.  The A13 pro is a much older model, so I would say that is very likely the Note 100 5G will be fully compatible.
hi @Randman
the phone might not work here.
Data is fine, but voice might not work
first, it is not on PM's VoLTE whitelist ( https://www.publicmobile.ca/en/get-help/articles/volte )
supposing, it can use 3G for voice calls , but Telus is reframing 3G bands and your phones might not have the much needed 1900 band on 3G , so 3G voice won't work
I suggest you choose a more mainstream phones that are designed and sold in Canada
Chalupa_Batman
Hello @Randman
To confirm if your phone will work with Public Mobile, please see this link. These are currently and mildly out of date lists of what can work.
The phone MAY work on the 3G network but will not work in the US or Mexico.
