07-06-2020 11:21 AM - edited 01-05-2022 11:59 AM
Im being told to enter my PUK number. Now locked out. Help please
07-06-2020 01:55 PM
This either means that your SIM is locked or your phone is locked. Contact either your carrier (or Samsung if applicable) or PM Customer service if it's your SIM that's locked.
07-06-2020 11:27 AM - edited 07-06-2020 11:30 AM
Here is a post from @Luddite from this thread
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/puk-locked-sim/m-p/471458#M36904
What is the message?
"SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
Once the PUK is recovered and validated, you will be asked to choose a new PIN.
Only Public Mobile's moderators can give you this type of code, which the device manufacturer cannot. Public Mobile's moderators can be contacted by submitting a ticket at: https://publicmobile.ca.ada.support/chat/
Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
07-06-2020 11:23 AM - edited 07-06-2020 11:25 AM
@Jumpman204 is this a network PUK code? or did you enter your sim pin passcode wrong 3 times?
if it's a network puk call Samsung or your previous provider to unlock your phone.
if it's a sim PUK then contact customer support here
make sure to check your inbox(top right corner envelope icon) periodically, for a message
