Promotion
08-31-2022 03:42 PM
I just signed up today for $25 plan with 1 G. Somehow I missed the promotion button for extra 2 G for the next 12 months. Do i need to cancel my account all together? or someone can help fix this.
Plans
08-31-2022 08:31 PM
@dust2dustNo, never did. Switched back from Koodo today and almost missed the promo and referral codes (you would have to specifically "add" the codes). I thought it may be worthy of a try for a new account.
08-31-2022 07:51 PM
@tzliu- Have you tried it? I've never heard of that box working for anything.
08-31-2022 07:45 PM
You may want to try to add the promo code under Plan & Add-ons Tab. Let us know if that works, otherwise, as suggested, contact CS.
08-31-2022 03:50 PM
Thanks for the help. I just send them a message.
08-31-2022 03:50 PM
Hi @GR Good to see you posting again 😊 PM updated the moderators to CSA awhile back, Customer Support Agent.
08-31-2022 03:48 PM
I believe you can message the moderators and they might put that prom on your account for you! Also you did use a refferal code to get the 10$ credit to your account? Just click on the tiny envelope on the top right hand corner of the page and send it to cs_agent and usually they get back to you within a few hours!
08-31-2022 03:45 PM
hi contact a cs agent ask them to add it
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
