3 hours ago
3 hours ago
If this promo is shown in your account under Subscription>Manage Subscription>Change Subscription then you can switch to the new plan anytime but I would suggest you switch on your next renewal date. If you click on NOW to switch. You will be charged for the old plan plus the new plan.
3 hours ago
Thank you.
3 hours ago
it's yours for as long as you keep it active or change to something else.
