Promotion for a limited time
THP_23
  • The promotion for a new subscribers only...
  • 20GB Plan for 29$/month
1 REPLY 1
Chalupa_Batman
Hi @THP_23
Yes, the plan itself is for new subscribers. However, if your current plan is for less than $29 and you want to upgrade, CS Agents have been known to upgrade. Here's a link to reach them. Just know, if your on a plan of $30 or higher now, the won't let you downgrade. This is a YMMV situation.
