12-09-2022 12:18 PM
I adhered for the promo at 40$ (4G and 15gig) and for some reason the plan isn't active. Why?
My Account
Plans
12-09-2022 12:28 PM - edited 12-09-2022 12:32 PM
Public Mobile has voicemail but not caller ID with the name showing. Only your phone number will show.
Great to hear you found your solution.
Enjoy your new plan and speed.
12-09-2022 12:28 PM
12-09-2022 12:27 PM
Ok, it seems to work that way. Quick question, do i still have voicemail and caller ID?
12-09-2022 12:24 PM
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
12-09-2022 12:23 PM - edited 12-09-2022 12:25 PM
Yes, login to your account using a different browser in incognito mode and try again. You'll see your new plan.
When in your account, try using the little refresh button. The circular wheel.
12-09-2022 12:21 PM
Hi
Yes i asked on my renewal date which is today the 9th
12-09-2022 12:19 PM - edited 12-09-2022 12:22 PM
Try logging into your account using a browser in incognito or private mode instead.
Your probably looking at old cached information.
The 4G speed won't kick in until 48 hours after your switch to 4G plan.
12-09-2022 12:19 PM
@Qcnomad did you opt for change on renewal date?
is today the renewal date?
try access My Account using Incognito mode and you should see the correct info
