04-03-2022
01:58 PM
04-04-2022
12:05 AM
computergeek541
Dealer gave me promo code and it was not accepted when I activated SIM card. What do I do? It was for new number. New account. Etc.
04-09-2022 05:45 PM
hi @JadenT if you activated within the time this promo was still valid PM CS Agent likely able to apply it back for you
Please open ticket with PM CS Agent to sort that outopen a ticket with Chatbot at: https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
04-09-2022 05:06 PM
@JadenT - if you met the terms and conditions of the promo explain what happened to customer support agents, and that you tried to add it but it did not work.
I have included methods to contact CSA above, link: https://productioncommunity.publicmobile.ca/t5/Get-Support/Promo-code-not-accepted/m-p/807818/highli...
04-09-2022 05:03 PM
it was the 12month2GB promo and I have the higher plan with auto pay.
04-03-2022 06:12 PM - edited 04-03-2022 06:12 PM
What was the promo code for?
2gb for 12 months or $10? This promo code will require a minimum $25 or higher plan. It doesn’t apply to $15 plan.
If you are referring to the referral code for a $10 credit, double check the code and don’t mix “O” with zero and the number 1 with “I”.
Both are on the last page 4 on the activation page.
04-03-2022 02:27 PM
@JadenT - if you could not enter the promo code during activation for some reason, tell customer support agents (CSA) what happened and ask them to add it on for you.
If you did not get your refer a friend referral code entered either, you can ask them to have it added as well so you receive $10 off your next renewal.
To contact Public Mobile Representatives (CSA), by either two methods, found here:
04-03-2022 02:04 PM
What was the code for? Free 2GB promo? Friend referral credit?
https://www.publicmobile.ca/en/ab/fs2020
It may take up to 2 business days for this data promo to show up.
04-03-2022 02:01 PM
Hi @JadenT I think that was a friend referral code you got. put the code as friend refer on page 4 of the activation . If still not working , activation first and open ticket with PM CS agent after
