07-11-2018 10:57 AM - edited 01-04-2022 06:26 PM
I am now getting the message, 'A problem sending this command to the Project Viewer'.
This has only just started.
I'm running IOS 12
Iphone 8
Can anyone advise me of a solution to this. Many Thanks
07-31-2018 01:48 PM
@Luddite wrote:
@Acekiller wrote:are you having issue with public mobile or just with some random files that you are trying to access?
"Project Viewer 365 for iOS is the only way to open up the .mpp file format on the iOS platform, without messy conversions or imports found in other apps."
@Luddite is like a wise owl who knows something about everything! ![]()
07-28-2018 03:51 PM
- Go to iPhone Settings.
- In Settings, tap to select one of your Office for iPhone apps.
- Under RESET, tap Reset .
- Slide to enable Delete Login Credentials.
- Start one of your Office for iPhone apps so that your credential is deleted.
- Sign in using your ID account. Note You may need to delete the credential for each Office for iPhone app. More Information: project recovery online
07-11-2018 01:53 PM
07-11-2018 01:05 PM
07-11-2018 11:42 AM - edited 07-11-2018 11:45 AM
iOS 12? You must be on the beta test programme. If so, you're on your own here. ![]()
Roll back to 11.4.1. Especially if your phone no longer gives service on Public Mobile.
