Process Payment
CrazyGnome
I'm trying to buy the $5 minutes add on but it won't process the payment for $1?
8 REPLIES 8
CrazyGnome
Just so you know an agent was able to add the $5 add on to my account. Thanks
CrazyGnome
Thanks but I already found the link in another thread.
CrazyGnome
Nevermind I found the link to send a private message to customer support. I will ask them.
@CrazyGnome   So you're not able to process the $1.12 (although wouldn't the tax would be on the $5 not the $1)?  You can contact customer service via this link
An agent will reply at your community inbox, envelope icon top right or at Messages under your avatar
CrazyGnome
It adds the tax so it is $1.12 total.
@CrazyGnome   Are you accounting for tax, depending on province?
CrazyGnome
I have $4 in my account. $4+$1=$5
Phil_Adelphus
@CrazyGnome   Can you elaborate, it sounds like you are trying to pay $1 for something that costs $5.
