04-29-2022 07:14 AM - last edited on 04-29-2022 07:15 AM by computergeek541
Out of sevice for 1 month now ! I need to access my account and I keep getting locked out ! All I want to do is add a new sim card .
04-29-2022 07:36 AM
@ken45 - No service for 1 month?!
Was this since April 1st, during when this issue was happening?
See "How To Change Your SIM Card" at the bottom of this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/sim-swap-fraud
But, if you had no services since your activation date, then it may not be a SIM card issue.
While you wait for a response from CSA if you submit a ticket as softech provided, can you provide a bit more details so we could try and help narrow down the issue?
04-29-2022 07:18 AM
Waif 15 minutes before trying again. Otherwise, please follow the forgot password procedure. Clicking on that option will guide you through the process.
04-29-2022 07:17 AM
@ken45 You want to "add" new sim card or Change the sim card for your current account/line? (maybe you lost your old sim and you are trying to replace the sim)
if you have a new sim card and you want to activate the new sim card for a 2nd line, you will need to activate using a different email address. You cannot use the same My Account for 2 lines.
For your access to the old account issue, you tried to use Forgot Password to reset the password? If you are unable to reset it that way, please open a ticket with PM Support and have them sort it out for you
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
