Problems since switching to Public Mobile
CelineG
Hello,
  Since switching to Public; at random, texts won't go through and I'm also not able to do phone calls. I reboot my phone many times a day. Any solutions??
THanks,
Celine
@CelineG
what phone do you have? exact model and brand? and outgoing calls work prefectly?
Please try these steps first :
  • reboot your phone once.
  • reseat your sim card (Power down the phone, take sim card out for a minute, then put it back and power up)
  • change your Preferred Network Type or Network Mode on your phone to 3G Only (or WCDMA)
  • Try to click Reset all networks and see if it helps (please note it will also delete your saved Wifi connections, but you can easily add them back later)
  • if you have another phone, put your sim card in that other phone and test
  • use your phone in another area, it could be a local network issue
But you still have the same issue after trying all above, then please engage support and ask them to reprovision your sim on the system:
CelineG
I have received calls and texts and have been able to do calls and texts also. It is totally random. Sometimes when rebooting it goes back to normal but today, no luck!
Will try to call them, thank you!
@CelineG
did you port in your phone number from another carrier?  If so, do you know if you ever able to receive incoming calls?  If you are unsure and don't think you ever receive incoming calls, then it is a problem with porting.  The number was not successfully ported yet.
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
