Problem with outgoing long-distance calls
NoelG
When I make a long-distance call to a number in ON, they cannot hear me.
If I receive an incoming call from that same number in ON, the call works, that is, we are able to hear each other.
If I make a long-distance call to a different number in ON, the call works.
Is the network affecting my long-distance calls?
NoelG
I performed a network reset, and the problem is resolved.  I was able to place a long-distance call and we were able to hear each other.
Thanks a lot for your help!
Public Mobile Community ROCKS!!!
Triguy
Try rebooting your phone.  Also if you have another then try swapping the sim.
Gunner123
@NoelG hi try a network reset see if that helps
