Problem logging in
Tess4
I'm not receiving my OTP. I am a brand new customer and just trying to log into my account for the first time. It says it is sending the code to my phone number but I dont recieved it, when I click resend code it just reloads the screen there is no option to send to email.
Silent
I’ve kind of experienced this before but I just had to just wait a couple of hours to receive a text.
CSA_PM
Customer Support Agent
Hi there. I sent you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Dunkman
@Tess4
I will escalate your issue to CS_Agent. They should contact you within 0.5-1 hour via private message.
TheSterlinger
Please message agents directly at the link below for assistance with logging in.
slusagm
Did you request porting phone number? If you did, check the text with the old provider sim card
If you still not receive the code there, ask PM
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
