09-30-2022 10:01 PM - last edited on 10-01-2022 01:02 AM by computergeek541
Hello
I have activated a simcard but i received this message
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided.
10-01-2022 01:03 AM
@BKNS27 wrote:Be patient and wait for the CS_Agent to contact you.
If you have the account number of your previous carrier would help
Although the text message about porting does say that, Public Mobile often will not contact the customer. The customer is very likely going to have to initiate that contact.
09-30-2022 11:49 PM
09-30-2022 10:56 PM
If you have not received a phone call yet, I will private message you the Telus porting number. This phone number is only used for porting issues. Not sure when they stop working though. Might need to call tomorrow morning if things are not fixed by then.
Here is some more information
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
09-30-2022 10:02 PM
open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot. themwill fix it for you.
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response from CS_Agent.
