Prize draws
Albsie
I'm new here, but I've heard lots about draws with public mobile. I don't see them anywhere, where can they be found? How do you enter?
@Albsie
There are no current contest right now. It will be posted on Announcement section so take a peek once in a while.
dust2dust
If you're saying you're new to Public then log in to the rewards/points page and see if there are any draws available to enter that would show in the catalogue. You "spend" a point for every entry.
@Albsie  There are sometimes phone draws in your rewards  portal of my account that you can enter with your points you earn . You can use them to lower your bill to 15 points for $15 off bill . Go browse the points catalogue and see .there’s add ons to choose also
