Private message
S_Morgan
Where do I reply to a private message? Tks.
2 REPLIES 2
HI @S_Morgan
just go to the inbox here https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
find the message you want to reply, at the bottom, there is a box saying Reply...   Click on the box and the box will change to full edit mode.  Once done, click Reply
@S_Morgan
Tap your avatar top right then Messages and at the bottom of the pm type in the Reply box then send.
