10-04-2022 04:38 PM - last edited on 10-04-2022 04:46 PM by computergeek541
I have 2 PM phone numbers under the same account.
One is designated as the primary and the second as secondary.
I want to change the designations - i.e., swap primary with secondary.
I submitted a ticket and the response was not understandable.
Could I get another explanation of how to do this?
Thank you
07-03-2024 07:33 PM
hi @Bnr
saying it is a scam, but what you have done to try to make it work?
as this service is real, the issue can be fixed by PM support agent, please submit a ticket with PM agent here
07-03-2024 07:28 PM
This service is a scam. I can’t even make outgoing calls. What a joke!!
10-04-2022 05:14 PM
Made a post on this topic 30 minutes ago.
Got lots of responses that solved my problem.
Thanks to all.
10-04-2022 05:05 PM
good info - solution found
10-04-2022 05:04 PM - edited 10-04-2022 05:08 PM
or the altemate number you see it it's for emergency contact,
there is actually no emergency for PM to call. More just for PM's record keeping
10-04-2022 05:00 PM - edited 10-04-2022 05:00 PM
@Kuehnbaum wrote:Perhaps I used the wrong terms. In My Account profile the 2 phone numbers show up as "Current" and "Alternate" not as primary and secondary.
Sorry, but what you're requesting can't be done. It is possible to do a number port of the alternate number into your Public Mobile acccount, but only if that phone number is from a different carrier. However, the moment that you do that, the number that was already in your Public Mobile account will be lost.
10-04-2022 04:58 PM - edited 10-04-2022 05:01 PM
@Kuehnbaum hi the alternate number you see in your profile is only a number for contact purposes only, if you have two public accounts they must be separate with separate emails or they will get messed up (seems like they have) you must get a customer service agent to separate them for you
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or private message them here
10-04-2022 04:54 PM
10-04-2022 04:53 PM
10-04-2022 04:49 PM
10-04-2022 04:44 PM
This service does not allow multiple numbers on one account. Did you activate in a store? After that, policy says you can't change numbers between accounts.
10-04-2022 04:44 PM - edited 10-04-2022 04:45 PM
@Kuehnbaum wrote:I have 2 PM phone numbers under the same account.
Thank you
There are no primary and secondary phone numbers as there can't be more than one phone number on the same account. Is it possible that Public Mobile is being confused with a simililarly named competitor?
