10-02-2020 08:54 PM - edited 01-05-2022 05:09 PM
Hi there,
I am getting prank calls since an incident happened with a guy that was using my car and my friend had to get tough with him because he owed me money. People do weird things. The number always starts with 403613 and I’ve taken screen shots if you need it.
I need it to stop, thanks!
10-13-2020 12:00 AM
You may find @Nezgar suggestion perfect solution to your problem.
10-12-2020 11:35 PM
Heh, you could also just forward your phone to Lenny- at least for declined/blocked calls. 🙂
10-12-2020 03:48 PM
Keep blocking the numbers.
The harassing caller will run out of phones and phone numbers long before your phone's software runs out of capacity to blacklist them.
Or you could consider changing your phone number. Though if this is a "friend" of a friend then he might be able to get your phone number again anyhow.
10-02-2020 09:28 PM - edited 10-02-2020 09:29 PM
@RosieR wrote:
@sunterthiner wrote:Hi there,
I need it to stop, thanks!@sunterthiner getting prank calls? oooh I don't think PM has an article on how to stop prank calls. Must be a small amount of money involved here, just let it go. As suggested above, just block the callers or treat them as spam. oh also, as already suggested above, you can always change your number. You cay change your phone number once every 30 days. Good luck!
I gotta think that to go to the extent of sending a friend to get tough would suggest that it's more than a little. Everybody would have their own line to cross though
10-02-2020 09:24 PM - edited 10-02-2020 09:51 PM
@sunterthiner getting prank calls? oooh I don't think PM has an article on how to stop prank calls. Must be a small amount of money involved here, just let it go. As suggested above, just block the callers or treat them as spam. oh also, as already suggested above, you can always change your number. You can change your phone number once every 30 days. Good luck!
10-02-2020 08:58 PM
@sunterthiner Keep blocking them. If you have device like Google Pixel, some spam calls are blocked automatically or you can use the screen call feature to find out if its spam before picking up. Changing your number is another option, but not everyone can easily go through the change.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
10-02-2020 08:58 PM - edited 10-02-2020 09:00 PM
For the most part, Public Mobile isn't going to help with this. Your options are to block the number or to change your phone number. If there is some type of illegal activity happening, you should be consdiering contacting your local police.
