Porting
jeanguybeaudry
Can I add a second number to my existing public Mobile phone?
@jeanguybeaudry
Unfortunately, you can only have 1 account/email address.
If you want multi SIMs on your phone but it has only have one SIM tray then there is a tray expander from a company online SIMore that you can put multiple SIMs with different phone numbers.
https://www.simore.com/en/
ShawnC13
If your phone is a dual SIM phone you can setup an additional account with a new sim and place it in your phone as well to have 2 numbers on one phone.
This statement is based on my interpretation of your question.
Quigley
@jeanguybeaudry
Sorry, you can only have one phone number per account or phone line.
But you can change your phone number up to 4 times a month for free.
If your asking if you can port in an existing phone number from another provider , into  PM to replace a current PM phone number.    Then yes, you can do that.
@jeanguybeaudry  No each account needs its own email …. But you could get e sim plan from say Telus if your phone supports it and keep your pm sim in the phone too have two lines on one phone
