08-29-2023 11:54 AM
I am a new customer. Activation failed and said to contact CS_Agent in our Community but no luck. I have no service it says sos and need help from an agent.
Service
08-29-2023 12:48 PM
Your old SIM will continue to work once porting is completed.
So keep the old SIM in your phone and once the agent restart s the porting process, reply with YES to the text confirming you are porting over to PM.
08-29-2023 11:55 AM - edited 08-29-2023 11:59 AM
@Coodogg Submit a ticket with Public Mobile representatives (CSA) for help; click this link for issues with transfer/porting of phone numbers over to Public Mobile.
Or, you can try calling the Telus porting phone number, which we are not supposed to post here. So, check your private messages I will send it to you there.
EDIT, I presumed you transferred a number over. But I don't actually clearly read that you were doing this. Sorry, if this was not a port over to Public DO NOT call that phone number (it is for porting issues only).
Did you restart the phone since you completed activation? Try the SIM Card into another phone to see if services work.
08-29-2023 11:55 AM
HI @Coodogg
i believe PM took the money already?
you tried to put the sim card in the phone and not connected?
please submit a ticket with cs agent here:
08-29-2023 11:55 AM - edited 08-29-2023 11:56 AM
@Coodogg Have you tried rebooting the phone ? Also No one will contact you . You need to private message support here’s the link
private message To CS_Agents click
VVVVV Link below VVVVV
