Porting problems from kodoo to public
SeemaS
I was a Koodo customer and my number isn’t porting, I can’t even log a ticket, having a hard time
Neil11
You will need to contact customer service agent to fix your issue.  Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
Bribri14
You will have to submit a ticket. Is your plan active? Ports won’t work without an active plan.
After opening the chatbot, typing "customer support agent" will allow a ticket to be opened.
