Porting numbers
Edkai
How do I get the port team to enter the correct info? Apparently submitted 3 times already to Speakout. Told by their agent that the need both IMEI and PIN
hi @Edkai porting from Speakout is trickier
But check with PM porting support team and confirm. I will send you the number to PM Porting support team Please check your community inbox
@Edkai
Are you porting into PM or out of PM?
Normally you need your previous account number and not the IMEI because you will run into problems use the IMEI.
