Porting number
05-23-2024
09:34 AM
05-23-2024
10:27 AM
computergeek541
I recently ported a number but received this text:
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://publicmobile.ca.ada.support/chat
no one has called, how do I update my MEID?
Joining Public
05-23-2024 10:28 AM
@FrannyG wrote:Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://publicmobile.ca.ada.support/chat
The text message that Public Mobile sends containts outdated information. The correct link to contact Public Mobile is
05-23-2024 09:43 AM
Yes, Public mobile is a Telus company so they use the same porting team.
05-23-2024 09:39 AM
Thanks, and the Telus guys are the people I update my MEID with?
05-23-2024 09:37 AM
I will send you a private message for the Telus team porting phone number. Only can be used for porting issue.
