02-03-2020 02:14 PM - edited 01-05-2022 10:31 AM
Hey guys,
So i recently ported my number from virgin mobile to public mobile. I was in a call with the virgin rep and getting my account number from them. And i got the account number and punched in the info and then pressed submit. The call i was in ended as soon as i did that and i went to sim card settings and it showed that i had successfuly changed my number. But now when people try to call my number, it says its not in service. So i dont understand the issue. Please help thanks! I've already tried restarting my phone.
02-03-2020 03:46 PM
@caps105 wrote:Hey guys,
Usually ports take a few hours even if you see that your number has been "ported".
I ported in from Fido and although my number came through in under a few hours, it took around 48 hours before I could receive calls and not just make calls.
02-03-2020 03:22 PM
Did you get Virgin to release your sim also? Bell had to send me a code I had to enter before I could even get on my phone after setting up with Public Sim
02-03-2020 03:22 PM
The port is likely not complete. Continue to use Virgin sim until it stops working, at which point the port is complete. Then insert PM sim to continue service.
02-03-2020 02:17 PM
@caps105 your port is probably stuck . Contact a moderator and explain your situation. Click on the green questionmark in the white circle at the bottom right of your screen. This connects to the autobot Simon . Type moderator and follow the prompts to get to one (CLICK on account specific question and human and submit a ticket). Welcome to PM .
02-03-2020 02:16 PM
Contact moderators.
Or private message them
