Porting A Number
Wilma_N
Have a question with regards to porting a phone number. My current carrier has an incorrect spelling of my name. Would that cause me a problem?
9 REPLIES 9
Naepalm
@Wilma_N
One thing to note here, and im not sure anyone mentioned it. sorry if I missed this.
When you port your number they will ask for the name on your current carriers account. Just make sure those names  match in that field.
But for Public Mobile you can definetly change your name to the correct spelling.
That would really be my only caution. Looks like everyone else has answered how to actually port your number over.
@Wilma_N To prevent fraudelent porting of your number, I would misspell it on your self service account.  As long as the name on the credit card is right. Or put a fake name ie Minnie Mouse.
@Wilma_N  Yes, you can spell your name correctly when setting up your account at Public Mobile as it doesn't make a difference. In fact, you can use any name you wish and it will still work.🙂
@Wilma_N , yes, correct that name of yours!
Wilma_N
Thanks, does that mean my name could be correctly spelled with Public Mobile?
gblackma
No @Wilma_N You can put the same incorrect spelling on your account here, as long the correct name us on your credit card address.
Here's 3 articles on activation and porting and the Refer a friend reward  if required:
1. How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
2. How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
3. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Welcome to PM. Stay safe.
geopublic
@Wilma_N  No, as long as you type it in as it's listed in your account then it's not an issue.
JoyLuck
Have a look at this link.
https://productioncommunity.publicmobile.ca/t5/Announcements/Number-transfer-in-Self-Serve-impacted-...
We recommend to take the following steps if you need to port-in a number:
  • Be sure to note the best practices below to ensure a smooth process:
    1. Only the authorized account holder can transfer a number.
    2. You cannot transfer numbers between Public Mobile accounts.
    3. Your previous account must be active in order for the number transfer to go through. Once the transfer is complete, it will be automatically deactivated from your previous service provider.
    4. Double check your old account info, as it needs to be correct in order for your number transfer to complete. Here’s the information you’ll need:
Mobile Phone Number Transfer
Landline Phone Number Transfer
Alternate Phone Number
Complete billing address
First and Last Name of the account holder
Alternate phone number
You’ll also need to provide one of the following: your old account number or your ESN/IMEI/MEID number or your account PIN
First and last name of the account holder
  1. As a new customer, we recommend porting a number at activation with the exception of Koodo Prepaid customers.
    • We have made some system enhancements to improve the success rate of this activity. So long as the correct information is entered, this process should be seamless
  2. All other customers: To complete your port-in request, please open our chatbot via this link and type in “port request” to be put in touch with a Moderator.
