Re: Failed phone number porting from PC mobile to public
tysono
Can you send it to me as well. Having the same porting issue
2 REPLIES 2
hi @tysono
Sent!  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
slusagm
yes, there is a porting assistance team you can call and ask for update.  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link:
And CS_Agent will reply to your community inbox, check here:
