08-22-2019 03:08 PM - edited 01-05-2022 06:35 AM
Hi, I have just activated my new SIM card. Now I would like to port my number from Koodo but can’t find where to do it. Any help would be great
08-22-2019 05:31 PM - edited 08-22-2019 05:32 PM
@Whitbyaus wrote:Correct, not familiar and clicked wrong button. My apologies. Can it be corrected?
@hairbag1 wrote:I agree it's unfamiliaritity with PM system....that's why I pointed it out and that he should select someone who (he feels) best provided a solution.
Don't worry about it it's all good as long as you're on your way. Welcome to PM!
08-22-2019 04:06 PM - edited 08-22-2019 04:07 PM
Yes, just click the 3 dots top right of your post to edit and unclick the solution.
08-22-2019 04:04 PM
08-22-2019 03:28 PM
08-22-2019 03:24 PM - edited 08-22-2019 03:26 PM
@hairbag1 It's probably done in error when you're not familiar with the whole system.
@Whitbyaus It's an easy mistake to make, you can correct as suggested by hairbag1, perhaps @ChuckYeah gave you the answer?
08-22-2019 03:21 PM
Hey @Whitbyaus ...you've given a SOLUTION to yourself....it's the correct thing to do is to provide SOLUTION to someone else who's actually given you a solution ? You can change things by clicking on the 3 little dots on top right side of the dialogue box and assign the SOLUTION to whomever you feel provided it.
08-22-2019 03:18 PM
@Whitbyaus wrote:Thank you. But where on the self serve account? Cant seem to find it
@Whitbyaus Selfserve fist page see below
08-22-2019 03:14 PM
Sorry didn’t see the last part. Thanks for your hep
08-22-2019 03:12 PM
08-22-2019 03:12 PM
Is it prepaid, if so:
Contact @Moderator_Team
It can take up to 48 hours for the team to respond to your concerns.
If it's postpaid, go to self serve here:
Plans and Addons -> change phone number
08-22-2019 03:11 PM
@Whitbyaus wrote:Hi, I have just activated my new SIM card. Now I would like to port my number from Koodo but can’t find where to do it. Any help would be great
If it's Koodo prepaid the you need assistance of Moderator_Team by clicking here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Koodo postpaid can done in your online self serve account.
