08-17-2016 06:53 PM - edited 01-04-2022 03:03 PM
I got a new SIM and plan with public and I'm trying to change my new number back to my old number with this new plan, but everytime I try it's says "We are experiencing in this process". I really need my old number back since I've used it for everything.
08-20-2016 12:59 AM
08-18-2016 01:03 PM
@Gabrielleblake further to my last question, if this is the case, why did you create a new account instead of just changing the plan on your old one? I'm just curious, as this isn't something we see people do very often.
08-18-2016 01:02 PM
@Gabrielleblake is @Luddite correct that you are trying to port a phone number from one Public Mobile account to another? Unfortunately, that doesn't work, at any provider. There was never provision for this built into the porting system when it was implemented a few years ago.
08-18-2016 09:13 AM
Hey @Gabrielleblake,
I have received the info in private, it shouldn't take too long before I reply back to you.
Please watch out for my reply, I might need additional info from you.
Thanks,
Shazia
08-17-2016 07:56 PM
Exactly. Customers cannot transfer numbers between accounts with the same provider.
Shazia has likely left for the day. If she is not on board tomorrow @Mary_M will pick it up.
Keep your fingers crossed.
08-17-2016 07:46 PM
08-17-2016 07:39 PM
@Gabrielleblake wrote:I got a new SIM and plan with public and I'm trying to change my new number back to my old number with this new plan, but everytime I try it's says "We are experiencing in this process". I really need my old number back since I've used it for everything.
If you get a new sim the procedure is to log into your current self serve account and select Change SIM. Once you enter the new sim number your plan, phone number, and account transfer to the new sim; log out and wait for service to begin with the new sim. After that log back into your account and select Change Plan, follow the prompts to pay for and activate the new plan. All done without waiting for a moderator.
08-17-2016 07:02 PM
I'm sorry about this,
Please do not post private info, this is a public forum accessible to everyone.
Can you please send me this info in private?
Thanks,
Shazia
08-17-2016 06:56 PM
Hi @Gabrielleblake!
Please edit your post to remove your phone numbers. This is a public forum. All personal information should be provided to the PM staff via private messages.
Lets alert one of the moderators @Shazia_K or @Mary_M to look into what can be done to help you.
08-17-2016 06:55 PM
