Porting a number from Freedom mobile
03-19-2019 02:10 PM - edited 01-05-2022 06:55 AM
03-21-2019 11:19 AM
Thank you very much
03-21-2019 11:09 AM
Yesterday I successfully ported my freedom mobile number. I did it through the activation process. The whole process took about 10 min.
03-19-2019 03:33 PM
Thank you
03-19-2019 03:33 PM
Thanks a lot
03-19-2019 03:17 PM - edited 03-19-2019 03:18 PM
Here is an illustrative guide on porting. Note that when entering the FM account number, do not include the hyphens. Only use the letters and numbers without spaces or separators.
03-19-2019 02:55 PM
Thanks
03-19-2019 02:39 PM
1: Get sim card ( preferably WOW, Walmart)
2: go to Freedom and get the account number
3: https://www.publicmobile.ca/en/bc/get-started
4: wait till transfer is done and you will get message saying that transfer request is completed successfully.
5: Enjoy the best service
03-19-2019 02:28 PM
Thank you
03-19-2019 02:23 PM
You get a sim card & go to Activate A Sim https://activate.publicmobile.ca and follow the process it’s easy. They’ll ask you choose a new number or transferring your number. You choose transfer your number & put info that’s it
03-19-2019 02:23 PM
Thank you
03-19-2019 02:22 PM
@vds71113 wrote:I didn’t get a SIM card yet.
I don't know about Freedom Mobile, but search this forum and read up on porting from Freedom. Here is a link with search results...
03-19-2019 02:21 PM - edited 03-19-2019 02:21 PM
You can take a look at this topic https://productioncommunity.publicmobile.ca/t5/Self-Serve/Porting-a-Number-to-Public-Mobile/m-p/3311...
it showed you how to port a number to Public Mobile. If you have an issue during porting number over, you should contact @CS_Agent for further help
03-19-2019 02:19 PM
03-19-2019 02:17 PM
Did you get an activated sim card already or you’ll get a new sim card to activate with Public Mobile?
