04-07-2020 06:26 AM - edited 01-05-2022 10:16 AM
I'm trying to port my number from PC Mobile Pre paid. Each time I try to log into the ticket, it says login unsuccessful. I'm about to cancel.
Joining Public
04-07-2020 10:41 AM - edited 04-07-2020 10:41 AM
04-07-2020 10:35 AM
When I try to sign into the ticket , I get a login error. I've tried waiting for a few hours and it's the same thing. I'm using my community username and password.
04-07-2020 07:59 AM
You will need to contact a moderator by submitting a ticket.
04-07-2020 06:53 AM - edited 04-07-2020 07:24 AM
Currently you cannot port from within your self service account. You require moderator help to do it @macsvo2 . Use this private message link to contact the moderators directly https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Type " Port Request " in the subject message field. Use this link to see what information is required to port your number https://productioncommunity.publicmobile.ca/t5/Announcements/Number-transfer-in-Self-Serve-impacted-...
Check your private message sent box (click on the envelope top right of your screen) to make sure the message was sent. Also keep an eye on the envelope, the mods answer will show up there.
You can also enable email notification to receive a private message notification sent to your email.
Go into your community account > my settings > PREFERENCES > Private Messenger > enable "Receive email notifications for new private messages" > Save
04-07-2020 06:34 AM
PC mobile needs to be ported by moderators.
Activate a new account and new number (which I think you have done) as it seems you are having issues with tickets. Use the alternate (contact method private message a(envrlope top right) and send to moderstor_team
