02-27-2019 08:41 AM - edited 01-05-2022 03:30 AM
How can we shift a number from some other company to Public mobile online?
02-27-2019 09:13 AM
Thanks
02-27-2019 09:11 AM
Thans
02-27-2019 09:08 AM
02-27-2019 08:53 AM
Or also through the sign-up activation process. But the preferred approach is as above after you've signed up with a new number and when you're all satisfied that the service will work for you.
02-27-2019 08:49 AM - edited 02-27-2019 09:08 AM
@Asima wrote:How can we shift a number from some other company to Public mobile online?
I've moved your post to its own topic. In future, for better visibility and thread clarity, its best to post your question to a fresh topic.
You can port your number from another provider by going to your PM self-serve account under "Plan & Add-ons" --> "Change phone number". Choose "Transfer a wireless or wireline number from another provider". Make sure the account at the old provider is still active. Ports can take a few hours to complete, during which you'll be able to make phone calls using your PM number, but not receive them. Note: If making any transfers from Koodo prepaid, you would require assistance from PM moderators, so in that case you would need to contact them by private message.
02-27-2019 08:42 AM - edited 02-27-2019 08:44 AM
It depends... from which company do you want to port your number @Asima ?
