06-14-2024 07:24 PM - last edited on 06-14-2024 09:09 PM by computergeek541
I signed up for the service but screwed up on the old account number. It wouldn't port. Then I screwed up and downloaded another esim. Can someone reset everything so I can start over or can someone please get a hold of me.
06-14-2024 07:40 PM
Have you completed your activation with the second e-sim?
06-14-2024 07:26 PM
@Zachary013 for porting, there is a team you can call. I will send you the number to your community inbox
for eSIM, do you have the eSIM installed on your phone?? I can tell you what to enable to make it work. Tell us if you you have iPhone or Android
