10-21-2016 04:40 AM - edited 01-04-2022 03:42 PM
Service
01-08-2017 03:31 AM
01-08-2017 01:36 AM
so if I signup for a temp number for a month, and during this month, I refer about 3 people, I'll get the discount as promised.
but then I come along and port my number to PM, what happens to my previous referrals? because they were referred by the previous temp phone number.
how does that work?
11-14-2016 01:49 PM
Hi @ferrarelli,
Thank you for reaching out to us.
I just looked into your issue and will send you a message in a little bit! 🙂
11-14-2016 01:24 PM
Hi @syed,
I'm really sorry about this,
If you haven't contacted another moderator already, could you send me your Public Mobile SIM card number via private message?
Thank you!
11-14-2016 09:16 AM
I've had an issue with porting my number. I did it around 1230 am on Friday, and evertyhing works except incoming calls. My phone doesn't ring when someone calls me and it goes straight to voicemail.
I've called my old service provider and they said they never received the request.
I did the same thing with my wife's phone later on Friday and it worked perfectly.
I've sent a PM to @Saray_O, and an email via the contact us link. Please let me know when I can expect a response via either mechanism.
Thanks!
11-10-2016 11:32 AM
hi syed
PM is currently experiencing a high number of requests so it may take them a while to reply. Please be patient, they helped me port my number, when i ported my number, there was a error in PM's system so they had to cancel my current account and create a new one.
11-10-2016 06:34 AM
11-10-2016 06:25 AM
Hi,
Yesterday i activated my opted to port out fro, virgin to PM. all done but i cannot recieve my call. and still my previous service is active.
its almost 48 hours and no response from PM nor my number is completely ported out. Please help me what to do next
11-08-2016 11:30 AM
11-08-2016 11:29 AM
I'm trying to figure out how to pay off my windtab balance.
I think thats why it wont let me port.
11-08-2016 11:27 AM
11-08-2016 11:25 AM
11-07-2016 07:31 PM
Hi Daredogg
I activated around 11am today, I'm porting from Wind Mobile.
11-07-2016 07:09 PM
@netboy12 so how long have you been waiting then? If you check out the Successful Ports Thread, you'll see examples of some of the port times we are seeing. What carrier did you port from?
11-07-2016 06:24 PM
When i requested a port of my old number, i activated my PM account and did the form and its 3:23 PM now and i still havent got a message saying that my porting request has being completed.
10-23-2016 04:17 PM
Thanks for confirming, @Mary_M. Most unfortunate, but good to know.
10-22-2016 08:56 AM
Hey @srlawren
That is correct. Once an account is an active, but the referred number was not entered, we cannot manually enter it.
Sorry about that 😞 !
Mary
10-21-2016 08:38 PM
@maaji my recollection is that it's not possible to enter the referral information, and I don't think the moderators can even do it, unfortunately. If I'm wrong, hopefully @Mary_M, @Shazia_K, or @Saray_O will correct me tomorrow.
10-21-2016 06:27 PM
Its all good. I decided on just porting now. The thing now is that while I was doing it I also was doing something else and realized that I clicked on no instead of yes when it asked if I was referred by someone. Is there a way to add the person as a referral now?
10-21-2016 05:17 PM
@maaji sorry I misunderstood. You could do that, but please bear in mind that an equivalent plan on a 10-day plan is quite a bit more expensive per day vs. the 30 day plans (and more so the 90 day plans). Also, bear in mind that your payment/renewal date will move from month to month, given that the plans are 30/90 days and not 1/3 calendar months.
10-21-2016 05:16 PM
10-21-2016 04:12 PM
Its more to do with billing like @dboxtvinfo mentioned.which is why I was thinking of the 10day more. I wanted to see others point of view on what they recommend.
Thanks for all your inputs.
10-21-2016 11:58 AM
@maaji I think @daredogg has answered your question really well. Please don't hesitate to ask any other questions you might have as well. 🙂
@dboxtvinfo the point of the 10 days is to have a comfort level. PM is a bit different in that there's no store to go to to speak to a salesperson, and nobody to call if the service doesn't work for you for some reason. You can assure @maaji as much as you like but everybody's circumstances could vary. For example, they may not have realized their phone has to be carrier unlocked (or locked to Telus/Koodo is fine) or that their phone wasn't compatible with the Telus network PM runs on, and all of a sudden they have an activated SIM and their phone number already ported in but they can't use the service and are stuck. Occasionally a SIM may arrive and not work correctly as well, and the person has to wait for a replacement. If you've still got your phone number active on your previous carrier, you have the time to work these out without risk of missing calls and texts. That's the point of the 10 day trial! Nothing wrong with it at all. In fact, I did it! Although I didn't run into any issues that would have left me without service, it was nice to have the peace of mind.
10-21-2016 10:26 AM
10-21-2016 10:22 AM
I assure you it works and you will have same issues too activate for 10 days or 30 days.
But it will be activated. Depends on your ability too follow instructions and comminicate community
10-21-2016 07:10 AM
Yes, that's what I'm saying... activate the SIM, but instead of porting your number during the activation, you can choose to have PM assign you a number (temporary in your case). When you're ready to port over your main number, you request that in the My Account self-serve.
One thing to note... you need to keep your account active with the current provider for the port to work. If you cancel with your current provider, your phone number could be lost.
10-21-2016 07:03 AM
10-21-2016 05:33 AM
If you wanted to try out the PM service, then yes, the 10-day plan is a good choice. When you activate the SIM, you have the option of immediately porting over your number, or having PM assign you a number. When you're ready to port over your number, there's a Change Phone Number in the self-serve My Account that will allow you to request your port.
This post shows screenshots of what the Change Phone Number page looks like. Look under Web Self Serve. How do I move my cell phone number to Public Mobile?
You can also refer to this post for more information about the porting process:
