3 hours ago
I want to refer a friend, but they want the same number. When selecting a plan and paying (for new client), is there an option to port before ur asked for credit card information?
Thanks!
3 hours ago
These are the following steps:
I assuming your are referring to steps 4 & 5 so they need to register a CC or debit (step 4) before porting the number or choosing a new number (step 5).
They need to complete the previous step before go to the next step.
3 hours ago - last edited 3 hours ago
Hey @Deepg821
Truth be told, what seems to be the most effective way is for your friend to sign up, use your referral code, get a temporary number with PM. Make sure it's all set up as in make and take calls and texts and the data works. Once that is complete, they can go into their profile and port over their number. However, I'd suggest checking this link to make sure the number can be ported first.
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
3 hours ago
yes, your friend likely can port the number. But check here to confirm (a Koodo link but Koodo and PM both use Telus system)
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
if it shows ok, then yes. The port request step is after the payment. So, make sure your use app to activate
