Add on data shows wrong usage
Aj30
Add on Data usage shows 50% used when i did not use cellular data
@Aj30 wrote:
I checked the usage in PM add on usage
tad confused now. check the usage in the add on usage or the app usage?
then ask PM to check.  Use the steps I provided above
Aj30
slusagm
if the wrong usage is showing on the app, make sure you click on Usage Breakdown on the main app page and it will show you the actual addon usage
if it still showing wrong, ask Pm to check.  You can open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this:
Chalupa_Batman
Hey @Aj30
Data updates 2 times daily. Sometimes website and app are incorrect. Go to browser settings, clear cache history and cookies. Restart browser and you should get a close to more accurate reading minutes last few hours or so.
