11-12-2016 12:00 AM - edited 01-04-2022 06:15 PM
11-12-2016 06:29 AM
11-12-2016 12:26 AM
sometimes it can take up to 72hours.
11-12-2016 12:03 AM - edited 11-12-2016 12:06 AM
You can port the number yourself. Just make sure your Koodo and PM email address are different. If it is the same change the email temporary, and change it back once your number is fully ported, you should get a text message when it has sucessfully ported.
Also make sure to check "I'm authorized..." before inputting any info. Just give your Koodo account number (without dashes or spaces), alternative phone number (e.g. home phone), and your name on your Koodo account.
However since the website is down for maintenance, you can try tomorrow.
