Porting Koodo Number
inkubux
Hi,
I just activated my sim-card.  As per the instruction I have created a new number and asked for a port from Contact-Us
I was wondering if I need to keep my Koodo sim in my phone while it's being ported or If I need to switch to the public mobile sim ?
And how long the process takes usually after the contact-us email has been sent ?
Thanks a lot for your help.
2 REPLIES 2
shnukms
Didn't take me that long, just to be safe I left my old SIM alone in the phone for an hour. Then after that I popped in the PM SIM and tested incoming/outgoing voice and SMS.
If your port didn't complete you won't be able to recieve calls - and those would still be directed to your old provider.
Ports generally could be longer depending if you're porting in a landline, or provided incorrect info PIN, IMEI when you were asked to fill in details on your previous provider, or a network issue.
AndreLaranjeiro
Keep the Koodo sim in your phone until the number is ported.  You will then get a "no service" message on your phone.  At that point you can remove that sim and put in your new sim and continue with activating your phone.  Welcome to PM :)!
